Page 2 of 2 FirstFirst 12
Showing results 11 to 13 of 13
Thread: awxDTools causes eplorer to crash
    I just experienced the same problem.
    And while reading I already mounted an image "the normal way",
    and just checked, and indeed it works.
    Lächeln THANK you!!!!!
    Thank you!!!! The 'mount from daemon-tools first' solution worked for me, and I didn't have to do the .NET repair.
    :: whew ::
    You rock, spiro!!
    Lächeln Vista SP2 Beta (v.113)
    I experienced the same problem after installing Windows Vista Service Pack 2 Beta. Mounting using the DAEMON Tools tray icon fixes the problem. Thanks ^^
