Showing results 11 to 20 of 25
Thread: Alcohol 120 Percent Version Info Thread
    Alcohol 52%/120% 1.9.6.5429 released
    Changelog
    NEW b5t, b6t and isz in image finder and shell extension options
    FIX Minor bugs found
    FIX Automount problem
    UPDATE Supported drive list
    UPDATE SPTD to v1.50
    Use the link below to get the trial version!
    http://trial.alcohol-soft.com/en/
    Alcohol 52%/120% 1.9.7.6022 released
    NEW Alcohol Xtra, Pre-mastering wizard
    NEW Reading Engine, Speed Improved
    NEW Writing engine, Speed Improved
    NEW Data Type Setting options for DVD medium
    NEW SPTD layer version 1.53
    NEW Increased memory buffer for x64 system, if you have more than 4GB RAM installed, the maximum buffer size could be set as 1GB.
    32bit system, 3GB ore more RAM installed, you can set max buffer as 512MB
    FIX Special ICH9 device drive incompatibility issues
    FIX Missing volume name of discs after auto mount upon system restart
    FIX Addressed some blacklisting problems
    FIX Bugs reported by some users
    UPDATE Help files
    UPDATE language files
    UPDATE Devsupp additional support for more drives
    UPDATE Upgraded Starwind ISCSI function
    UPDATE ISCSI controller in Vista, admin mode is no longer required
    v1.9.7.6221
    2008-02-22
    * NEW DVD/CD Drive EDM System (Enable/Disable Manger
    * NEW Improved Dumping/Burning engine more stability and speed
    * NEW Blu-ray format (single and double sided) are supported in the Xtra Wizard
    * NEW Blu-ray format (single and double sided) are totally supported in Alcohols Burning & Dumping Wizard now.
    * NEW DPM extraction and writing for more accuracy with some drives.
    * NEW Performance graphic now supports Blu-ray format (single and double sided)
    * FIX Problem with some Drives Not showing correct manufacture ID of blank discs.
    * FIXThe incorrect 'Processor Info' display on some Operating systems
    * FIX Addressed some blacklisting problems
    * FIX Bugs reported by some users
    * FIX Auto play doesn't show in x64 platform problem
    * Update |Some language files
    * UPDATE Devsupp additional support for more drives
    v1.9.8.7117
    2008-11-23
    NEW A.C.I.D Wizard "Alcohol Cloaking Initiative for DRM"
    NEW Add Context Menu in explorer for burning image file
    NEW Latest SPTD layer version
    FIX The incorrect 'Processor Info' display on some Operating systems, especially for Core 2 Dual new processors
    FIX addressed some blacklisting problems
    UPDATE Some language files
    Alcohol Soft trial version download
    Alcohol 120% 1.9.8.7507
    Changes in version 1.9.8.7507, 2009-03-17:
    NEW Improved Dumping/Burning engine, better stability and speed
    FIX Issues with Vista User Interface
    Alcohol 120%/52% 1.9.8.7421
    New Improved Dumping/Burning engine more stability and speed
    New UAC (User Account Control) is fully supported in Vista.
    New iSCSI sharing center will now notify the user if windows native firewall is on and enable the user to add it into the exception list automatically.
    New Vista SP2 Beta fully supported
    FIX Problem, where some Drives were not showing the correct manufacture ID of blank Media.
    UPDATE Devsupp additional support for more drives.
    27.05.2003
    386
    Alcohol 120% 1.9.8.7530 2009-04-02
    UPDATE Read and Write engines
    UPDATE Language files
    UPDATE Devsupp.dll offering support for more drives
    UPDATE A.C.I.D to V 1.1.9040
    FIX User reported bugs
    Default ...
    I'm a Alcohol 120% user, I use it to make images of all my CDs so my kids don't have to handle them & risk scratching them.
    I have been using Daemon Tools on the kids PC to mount the images so they can play their games though now I'll check out the Alcohol 52% as an alternative.
    I always thought it was a bit off to charge for the 52% since it's pretty useless without the 120%
  8. #18
    GEORGIAN TRANSLATOR OFFICIAL TRANSLATOR
    sikvdila's Avatar
    05.07.2008
    138
    changelog: 1.9.8.7612
    NEW Supports Windows 7 Beta versions
    UPDATE SPTD to 1.58
    Still have't Win 7 Support completely :|
    Georgian Translator
  9. #19
    The moon is here
    22.06.2008
    549
    Quote Originally Posted by sikvdila View Post
    ??? Win7 IS FULL supported by Alcohol120! (silent update)
  10. #20
    sikvdila's Avatar
    05.07.2008
    138
    Quote Originally Posted by moonie View Post
    Alcohol Soft Product Support
    here is changelog
    Georgian Translator
