Page 3 of 3 FirstFirst 123
Showing results 21 to 25 of 25
Thread: Alcohol 120 Percent Version Info Thread
  1. #21
    The moon is here
    22.06.2008
    549
    believe me i know the changelog ^^
    Look @ Alcohol-Soft.com "compatible with Win7"
    i use Alcohol and have no Problems with Win7!
    have you any probs?
  2. #22
    GEORGIAN TRANSLATOR OFFICIAL TRANSLATOR
    sikvdila's Avatar
    05.07.2008
    138
    Quote Originally Posted by moonie View Post
    have you any probs?
    No I don't using alcohol, I just post latest changelog
    Georgian Translator
  3. #23
    The moon is here
    22.06.2008
    549
    send you a PM
  4. #24
    The moon is here
    22.06.2008
    549
    Alcohol 120% 2.0.0.1331 vom 04.02.2010
    NEW User Interface with Full Unicode Support
    NEW Folder Management
    NEW Enhanced Reading Writing Engines
    NEW Audio Converter Plugin for MP3 Conversion
    NEW Alcohol iSCSI sharing Centre
    NEW Built in Protection Scanner
    NEW SPTD Version 1.62
    Audio Plugin can be downloaded from
    Alcohol Audio Converter
    Once installed select Device>Audio Converter
  5. #25
    pseudo555's Avatar
    05.11.2004
    126
    2010-09-17 : 2.0.1.2033
    FIX Xtra Wizard Window Opening Problem.
    FIX Please download again if you have Russian Language missing.
    UPDATE Drive support updated.
    2010-09-10 : 2.0.1.2031
    NEW Save XML Image File List
    NEW SPTD virtual-drive kernel
    UPDATE Language Files
    UPDATE SPTD 1.74
    FIX minor bugs fixed.
    FIX Invalid Image Size error
