Showing results 1 to 3 of 3
Thread: recording option
    09.11.2006
    1
    Default recording option
    be able to create an cd/DVD RW instead of a normal drive.
    so if you use backup software or something els and you want to burn it onto DVD, but you don't have a DVD-rw drive, you can select the Emulator and burn in into an ISO file.
    this way you don't have to have a DVD-RW drive in all your systems or burn an rip dvd's all the time
    And why do you post in "Daemon-Homepage Suggestions You think the Site/Boarddesign sucks??"?
    You want a virtual burner if i understand you right?
    Reef's Avatar
    30.03.2003
    860
    Something like that can be done with Nero (select Image Recorder from device list), or you could also use a program like UltraISO to create an ISO file.
