Showing results 11 to 20 of 26
Thread: yasu.exe to d-tools directory
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    There is no YASU 1.7.
    Just use latest DT (4.30.4) and YASU (1.6.9040) and there'll be no need to rename anything
    09.04.2009
    1
    Easy rename DTLite.exe to daemon.exe and run YASU
    1st-sorry for my english
    i made this
    make a copy of DTLite.exe then rename a copy to DTPro.exe
    and put it back in the folder - yasu will work
    because the icons (file association) disappear
    youngneptune
    Guest
    I just downloaded and installed the latest DT and YASU. But it tells me to find daemon.exe or dtpro.exe.
    Renaming them does not work either.
    27.09.2005
    822
    and you put yasu in the SAME folder as daemon tools?
    youngneptune
    Guest
    @ evlncrn8 - Yes I copy-pasted the yasu.exe to the installed directory:
    C:\Program Files\DAEMON Tools Lite
    But it is not detecting the files even if I rename them.
    youngneptune
    Guest
    Just an update: I tried installing the same software (DTlite and YASU) on to a different machine (my laptop). It worked! So I'm guessing the problem is something to do with my desktop - I haven't figured out what the problem is though.
  8. #18
    youngneptune
    Guest
    So there's no solution to this other than formatting my desktop? No suggestions what so ever? I run AVG as security, but I'm sure that's not causing any issues. One difference I noticed between the laptop installation and the desktop installation/s was that the former asked for a language option; while the latter didn't.
  9. #19
    22.12.2009
    1
    Same problem. DT Lite v.4.35.5.0068 / Yasu 1.6.9040
    Unable to locate the file ''daemon.exe'' or ''dtpro.exe''. Please copy... blah.
    Tried renaming and everything that was suggested here, still doesn't work. Can someone maybe suggest earlier versions that will work together?
  10. #20
    27.11.2009
    3
    Unglücklich
    Quote Originally Posted by ppk55 View Post
    Yeah, I have the very same problem (with the very same error message). OS: Vista Ultimate 64. No solutions so far!
