Showing results 21 to 30 of 38
Thread: your suggestions for new features in Astroburn?
  1. #21
    29.07.2008
    1
    Option: Do not eject the disk after the burn is complete.
    Please.
  2. #22
    Pfeil
    Simple user-interface as "SESSION" Mode make it the ideal partner for all users that need a burn solution.
    Best regards..
  3. #23
    When you don't finalize the disc, you are burning a session.
    Quote Originally Posted by wega View Post
    Please.
    Hi, new user here! Just bought a license myself.
    I second the above. The only thing I miss is an option to do not eject the disk after the burn is complete. Astroburn Pro is amazing!
  5. #25
    I'd like to be able to burn audio cd's and have the option to select a 0 second gap between songs. Just like I can do in Nero Burning Rom.
  6. #26
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Quote Originally Posted by Number99 View Post
    Try to use Astroburn Pro. Select 'Audio CD' file system, add files to project and set desired pauses between tracks (left click on Pause in appropriate row to change value).
  7. #27
    It is possible already, you just need to check the option "disc at once" before burning the disc.
  8. #28
    Oh! I wasn't aware of this! I can't believe how I could have missed it! Thank you very much
  9. #29
    Feature suggestion: ability to burn multisession discs. Is this a planned feature addition or is it not possible in Astroburn Pro when using the copy disc option?
  10. #30
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Astroburn Pro and Astroburn Lite are able to burn multisession discs.
