Page 4 of 4 FirstFirst ... 234
Showing results 31 to 38 of 38
Thread: your suggestions for new features in Astroburn?
  1. #31
    SPANISH TRANSLATOR OFFICIAL TRANSLATOR
    26.02.2006
    48
    Before burning a disc, detect if the files really exist.
    For example, if after adding the files to the project you go and delete or rename them, when you click to burn the disc Astroburn Pro starts the process, despite the files cannot be found.
  2. #32
    UKRAINIAN TRANSLATOR OFFICIAL TRANSLATOR
    oder2's Avatar
    29.09.2005
    368
    Well, checking for the existance is not much sense. The files may be as well gone after the burning was started.
    Btw, that's the reason there is usually no function available for file existance check in APIs. The file might be there while you were checking for it but before function returns it might be already deleted.
  3. #33
    12.04.2011
    2
    In the settings: Remember window position
  4. #34
    12.04.2011
    2
    Creators audio player for listening to CD's of images in formats FLAC, APE, Wav, MP3-style Astroburn Lite
    Aluminium
  5. #35
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Quote Originally Posted by 36.06 View Post
    Will be fixed in the next versions.
  6. #36
    09.06.2005
    3
    Ability to add folders as well as files to DATA/DISC.
    DVD Video support
    Bluray support
  7. #37
    Ability to burn multiple copies. Right now if you want to make 3 copies of the same disc you have to write an image file and burn it 3 times. Copy and burning options could use a "Copies" field that automatically burns more disc using the same source (eg a temporary image in case of of a disk copy operation)
    Co-Creator of Akkadia MUD Game Engine Codebase (GPL 1999)
    In /dev/null no one can hear you scream!
  8. #38
    able to burn mac images .dmg
