Page 2 of 9 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 84
Thread: ProtectionId Info thread - Current 6.3.5
    GERMAN TRANSLATOR OFFICIAL TRANSLATOR
    Hanschke's Avatar
    16.11.2005
    503
    ok if u dont can talk about this. so i have to wait and see i think the icons are very small if u have got a monitor with a high resolution. i will play if i have more time with it.
    Thanks for the X-mas Update!
    11.09.2005
    239
    Nice job guys!
    Thanks for this update!
    Beitrag
    Also of me a large thanks for the PID v6.0 Public XMAS BETA.
    27.09.2005
    822
    cheers all, surprised noone has whined about the gui, on other forums people complained that they didnt like it.. but i think compared to v5 gui, its a lot better...
    any constructive criticism is welcomed...preferably with a bit more info than 'i dont like the gui'...
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Well, here's some criticism for you. Whether it's constructive or not, I'll let you judge. Nix the voice at startup. It's very annoying.
    *EDIT*
    Never mind, I found the option to disable "speech". But it's still annoying that it's enabled by default.
    27.09.2005
    822
    will be disabled by default in next build.. promise
  8. #18
    Default Beta
    I just wanted to say thank you too Great job, on a nice piece of software. And its really easy to use.
  9. #19
    18.10.2005
    242
    thx cdkiller2k and thx to anyone who was involved in making this!
    greets to cdkiller & bob2k from Neo, please
  10. #20
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    I do have one suggestion for ProtectionID, and it's something that's always bugged me about it. With A-Ray scanner, it will only display relevant results, e.g. it only displays the actual copy protection detected. In PID, it displays EVERY file that it scans, regardless of whether the file is copy protected or not. If I'm scanning an entire directory or a disc, I then have to scroll through a number of listings in order to find the ONE that I'm looking for. It's the sole reason why I still keep A-Ray on my system, in spite of it not being updated anymore.
