Page 3 of 9 FirstFirst 12345 ... LastLast
Showing results 21 to 30 of 84
Thread: ProtectionId Info thread - Current 6.3.5
  1. #21
    Quote Originally Posted by Jito463 View Post
    I do have one suggestion for ProtectionID, and it's something that's always bugged me about it. With A-Ray scanner, it will only display relevant results, e.g. it only displays the actual copy protection detected. In PID, it displays EVERY file that it scans, regardless of whether the file is copy protected or not. If I'm scanning an entire directory or a disc, I then have to scroll through a number of listings in order to find the ONE that I'm looking for. It's the sole reason why I still keep A-Ray on my system, in spite of it not being updated anymore.
    Enable Log Filter
  2. #22
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Hmm, I wasn't sure what that was, so I didn't mess with it. That helps, though it still focuses on things that don't matter (like [-= Installer =-] Wise Installation Wizard Module !). I suppose the only thing left is to disable auto-scrolling in the log window. Makes it hard to read existing scans until the scan is completely finished. I looked through the configuration page and didn't find any reference to scrolling in the log window.
  3. #23
    27.09.2005
    822
    watch the 'protection log' window instead of the main log window (2nd button down on the left side)
    autoscroll on the main log window (1st button, left side) is always enabled, because other things can use it as well... so it probably wont be disabled anytime in the near future
    i could make another option to 'skip' types..
    like the installer etc you mentioned...
    skip installer, skip dongle etc..
    would that help?
    documentation would also help, cdk's doing that though, should arrive soon... its a beta for a reason
    v5 also had a log filter if i remember right.. haven't looked at it in ages tho..
  4. #24
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Ah, that makes a world of difference. I'm used to the "log window" from PID v5, so that's where I looked automatically in PID v6. I don't really care about the installer detections, but it doesn't make much sense to bother with if you ask me.
    *EDIT*
    By the way, one more option might be to "clear" the log window, so we don't have to close PID to clear it.
    *EDIT2*
    No, PID v5 didn't have a filter on it.
  5. #25
    27.09.2005
    822
    *EDIT*
    try right clicking in the windows...
    a lot of things in pid6 have context menus when right clicked.. like the folderwatch etc..
    *EDIT2*
    hmm think you're right, well at least the public one didnt...
    my memory is a bit fuzzy about v5, compared to v6 its a dinosaur heh
  6. #26
    04.11.2005
    28
    Great program!
    Any chance for adding audiocd protection detecting?
    Although the program size is still small,it's loaded with some features that have nothing to do with protection scanning.Wouldn't mind to see those repleaced with some CDS200 or Key2Audio discoverers...
  7. #27
    27.09.2005
    822
    well plugins might support that later on.. if you have more info on the cds/key2audio thing pm me, and we'll see what can be done.. but protection id is a protection scanner.. not a remover
  8. #28
    Edit: sorry, was answered before, deleted!
  9. #29
    Kitna's Avatar
    24.02.2003
    479
    Quote Originally Posted by evlncrn8 View Post
    CDS200 == Cactus Data Shield is a copy protection not some kind of DRM so it should be easy enough to add. I have a protected disc here somewhere IIRC. (edit: I do, the presence of an 800MB dummy file named yucca.cds reveals it, as well as a copy protection label on the disc itself.)
    I'm pretty sure Key2Audio is similar.
    Congrats on getting PID v6 public beta out, looks promising.
  10. #30
    27.09.2005
    822
    cheers, i'll try researching it, i have no audio disks with protection here so currently any of the scanning code for this will be theory (unless cdkiller has a protected audio disk)... for example, is the yucca.cds generic amongst all cactus data shield protected disks etc...
