Changelogs for ENU.dll
This is a sticky topic.
  • I see. Thank you for your prompt reply. h66h is doing high quality Traditional Chinese language translation.
    • Changed string over at astroburn.
      • New and changed strings are available.
        • Added two new strings for normal Site Translator.
          • New changed strings.
            • New strings for Astroburn.
              • All new strings translated. Thanks for infos, as always.
                • New and changed strings.
                  • Done.
                    享受您的身体 利用您的脑壳
                    • Astroburn Translation file appears to be corrupted.
                      享受您的身体 利用您的脑壳
                      • Yes, I noticed the same thing...
                        Maybe someone in dev-department knows? Hope this will be corrected soon, so that translating can continue...
                        Anyway, Happy New Year 2009 to everyone!!!
                        Ludwig
                        • I just checked some DT Pro translations and some translators are translating "DAEMON Tools Pro Advanced" which is a bit wrong as the product is called so and you don't translate product names. Same for "Standard".
                          • Astroburn translations site is up again.
                            • 2 changed strings for DT Pro.
                              • Hi
                                I've noticed a few not translated strings in latest (4.30.0304.0047) version of DTPA:
                                - "Customize..." when you press a little arrow on the toolbar and select Add/Remove buttons;
                                - "Toolbar Options" - hint text over that little arrow;
                                - "Hide" - hint over Info Panel close button;
                                - Animation styles in Customize/Options
                                I couldn't find them in DLL Translator.
                                Somehow I was not able to take a screenshot with hints displayed :/
