Page 2 of 5 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 41
Thread: Daemon Tools Pro drive error: -1
    Open boot.ini in c:\ and add the following at the end of your Windows "/EXECUTE"
    It should look like this:
    [operating systems]
    multi(0)disk(0)rdisk(2)partition(2)\WINDOWS="Micro soft Windows XP Professional" /FASTDETECT /EXECUTE /USEPMTIMER
    Ensure there is no /NOEXECUTE in this file.
    I get the same error message when trying to set the # of drives except I get an error: -2 instead of -1. Is there a difference? I'm running XP.
    24.03.2009
    1
    Hi, first post on here,
    Having same problem but.. my boot.ini has this:
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Home Edition" /noexecute=optin /fastdetect
    It has no execute, but I'm still getting the error..
    What needs to be done?
    Thanks,
    bf1
    Blinzeln I'm reading it like this:
    The instructions* seemed to say that you need to delete the "/NOEXECUTE" paramater and replace it with "/EXECUTE"
    * From previous posting by Blazkowicz
    [operating systems]
    Ausrufezeichen Explain please!
    [operating systems]
    I tried it but it doesnt work. Should I reboot it????
    MY OS is XP sp2. And my boot.ini file looks like this
    [boot loader]
    timeout=30
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /noexecute=optin /fastdetect
    Please Explain in detail what to change! Thanks in advance!
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Code:
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
    You need to read the directions a little closer. You should change the above to the following:
    Code:
    [boot loader]
    timeout=30
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /execute /fastdetect
    Ausrufezeichen Doesnt work!
    Sorry it doesnt work! so i use alcohol 120! Still prefer daemon though!
  8. #18
    27.09.2005
    822
    think that setting is for dep isn't it? and i dont think its the reason here, cos i have dep on on one of my pc's, and off on the other and have never had a dt pro problem when installing
  9. #19
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Yeah, that changes DEP settings to disabled. I don't know if it fixes anything or not, I was just helping mura figure out what to do. I never turn off DEP on any of my machines and have never had an issue with Alcohol or DTools Pro.
  10. #20
    27.09.2005
    822
    same here, i think the problem has to be something else
Tags for this Thread
