Page 3 of 3 FirstFirst 123
Showing results 21 to 23 of 23
Thread: Assassins Creed and Gears of War problem
  1. #21
    27.03.2003
    105
    There are two (german) threads in DT forum that ensure Assassin's Creed is working fine in vIDE
    - without contrary reports.
    And be assured we'd have seen many reports if there was a problem with that title/SD version.
    One user had problems starting Assassin's Creed in vIDE (link).
    The solution was uninstalling DT lite.
    Do you have DT lite installed ?
    I do have DT Lite installed as well. I'll update this thread presently...
    BINGO! Worked like a charm. Thanks Terramex.
    Might be a good idea to put this kind of info in the product release notes?!?
  2. #22
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    Quote Originally Posted by professorx View Post
    It's no general problem. I also had a parallel installation of Pro/lite without problems.
    And with the current build parallel installations aren't possible anyway
  3. #23
    26.01.2008
    17
    I wonder which image format u selected? and should I pay any other attention to make a safedisk protected game?
