Page 3 of 19 FirstFirst 1234513 ... LastLast
Showing results 21 to 30 of 181
  1. #21
    Reef's Avatar
    30.03.2003
    860
    Syk0's new tool? Did I miss something?
  2. #22
    27.09.2005
    822
    im sure he'll announce it soon, it was just 'born' today afaik
  3. #23
    There is no need for an undo feature as it will be undone by Windows on next start.
    Also i guess sYk0's new tool is destructive like YASU is atm.
    And i can bet new tool will be blacklisted very soon (especially since it has mostly no protection) and also its changes.
    27.09.2005
    822
    so the changes to the hardwareid portion in the registry are rebuilt by windows on boot? .. dont think so blazi.. it permanently changed them on my machine
    by destructive i meant it changes registry data, without backing it up... it definately did this on my machine.. i had to fix it manually, and vmprotect hardly protects dte against blacklisting.. all tools will get blacklisted eventually, thats inevitable
  5. #25
    Well, i tested on several OSes (multiple Vista and a few XP) and they get rebuilt everytime on windows restart. Also these changes doesn't harm like YASU's one sometimes.
    Sure about blacklisting, but DTE only has to run once in a windows session (except a new drive gets added) and YASU have to stay open and there a blacklist can be easily implemented. Except sYk0 changed it on his new tool.
    Anyway let's just wait until sYk0's new tool is released and then we can discuss a compare between both tools again.
    @mbf-4
    You have enabled DEP or not?
    24.09.2008
    14
    dep current status:
    enabled only for windows services
    boot.ini config:
    /NoExecute=OptIn
  8. #28
    24.09.2008
    14
    Just tried dte version 1.0.0.1 (modified:14.12.08) and it works...
  9. #29
    It doesn't support 304 and SecuROM.
    I guess you have Comodo Firewall installed, if not, then please tell us your security software.
    24.09.2008
    14
    yes, I have comodo firewall 3.5.57173 installed, but I turn everything off before installing/running dt and dte. do you think I should uninstall CF completely to make dte work?
