Showing results 11 to 20 of 35
Thread: Omen: The future of Anti-Blacklists is near...
    Quote Originally Posted by chitan View Post
    and to add ta necrovision is using SR 7.38 not 7.39 as it was mentioned
    My Russian Necrovision is using 7.39.
    Ptolomeus3's Avatar
    23.05.2004
    167
    My sons Fallout 3 with newest Patch v1.4.0.6 (German) doesn't work anymore.
    DT & AS Customer. AS Support Team Member.
    27.09.2005
    822
    "doesn't work" can cover a multitude of things.. can you elaborate on it?.. .eg: emulation detected, please insert correct disk, crash etc...
    more information helps
    jusdging by the excitment this post has caused it makes me think i should stop searching for a solution until this program is released. My fiance has/had a multimedia dvd that she uses for her degree (no patches out there). at a whopping 90 pounds I backed it up as our dog likes dvds. The dog got it and now I have delved into the world of securom (v. 07.38.0006) and "a required secrirty module can not be activated". Does this mean as of right now there is no workaround out there?
    Thanks
    @SeanyP321
    Click on the link in SecuROM message and tell us what it says there exactly.
    running DT lite 4.30.3 and YASU it says "a required security module can not be activated. This program can not be executed." and gives me an ok button. Whats weird is the very first time I installed DT, it worked (once). No hair left!!
    Any advice would be v much appreciated!
    YASU is blacklisted, therefore that error.
    are there any vista savvy programs that ar not b..listed???
  9. #19
    noooo come back blazkowicz! come baaaack
  10. #20
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    @SeanyP321
    AFAIK last YASU version 1.5.8111 is not blacklisted by SecuROM 7.38.0006.
    But maybe you better start a new thread concernig that multimedia dvd as we're going a little bit offtopic
