Page 2 of 6 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 56
Thread: YASU 1.6.9040 released
    Is it normal, that it does not work with DT Lite 4.30.2 (of course I should upgrade to latest version but such a version check is quite special)
    "Unable to authenticate DAEMON Tools Lite or DAEMON Tools Pro"
    Yes, it is normal. Only latest Pro and Lite versions are working.
    Is it normal that the log infos are not shown in the status window (However, I can copy the logs to clipboard via "Log"-Button)? Looks a bit strange
    DT Lite 4.30.3 is used.
    (sorry for all the questions)
    No, it is not normal.
    Which OS are you using?
    Default It is really a shame that 1.6.9040 still not correct the problem in 1.5.8111
    It is really a shame that 1.6.9040 still not correct the problem in 1.5.8111.
    10:56:08 Y.A.S.U v1.6.9040 started...!
    10:56:08 DAEMON Tools Lite v4.30.3.0
    10:56:08 Microsoft Windows XP v5.1 (Build 2600: Service Pack 3)
    10:56:08 Locale: 中文(中国)
    10:56:08 Detected 3 optical device(s), 2 physical & 1 virtual device(s)
    10:56:22 * Cloaking procedure started.
    10:56:22 1 device(s) successfully cloaked from SecuROM 7.xx:
    10:56:22 [
    10:56:22 [
    10:56:22 [ J:\ ] Status = Successful
    10:56:22 * Cloaking procedure completed.
    10:56:30 * Uncloaking procedure started.
    10:56:30 0 device(s) successfully uncloaked from SafeDisc 4.xx:
    10:56:30 [
    10:56:30 [
    10:56:30 [ J:\ ] Status = Ignored (does not require updating)
    10:56:30 0 device(s) successfully uncloaked from SecuROM 7.xx:
    10:56:30 [
    10:56:30 [
    10:56:30 * Uncloaking procedure completed.
    You can see that SR7 cloacking is not completed while cloaking.
    For a similar case,you can check follow link:
    http://forum.daemon-tools.cc/f40/%5B...securom-22643/
    Also,what is the "[" line display?Word missing?
    I'm using Windows XP Professional 32Bit with ServicePack3. German Version.
    What information do you need additionally?
    Lächeln Great job Syko!
    Great job Syko! It's perfectly working with SD 4.85.
    ( I was waiting for it since two months Many thanks!)
  8. #18
    22.10.2004
    3
    YASU 1.6.9040 perfectly run fine on every game i tested...
    just small prob to me... YASU can't bypass the startup permission check Vista SP1 64-bit & a window error
    default startup registry entry by yasu give me a windows error like this after i allowed to run from taskbar windows defender block
    despite i already placed YASU.exe on the same main daemon tools folder(DTPro.exe). i make startup registry via yasu commandline -a -s -c.
    in order yasu run startup on my pc, i moved default YASU registry to normally startup shortcut at StartMenu->Programs->Startup
    but still afterward i must allowed yasu to run via taskbar windows defender block startup permission check.
    kinda annoying with everytime my system bootup i must click on taskbar to accept & allow yasu to run coz windows defender block
    any idea to bypass startup permission check beside turning off UAC(User Account Control)?
  9. #19
    sYk0's Avatar
    27.12.2005
    392
    Hi cyk0rz,
    I am aware of the startup bug, it has been fixed and will be in the next update of YASU.
    Regards,
    sYk0.
    Quote Originally Posted by cyk0rz View Post
    Mail:
    curerom @ daemon-tools.cc
  10. #20
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    @cyk0rz
    In the meantime you can try the Microsoft Application Compatibility Toolkit to create an exception that isn't checked/blocked by User Account Control.
    Here you can find an example (german, but with engl. images):
    http://space.wismar-wacken.com/thomas/Files/MACT.pdf
