Page 7 of 9 FirstFirst ... 56789 LastLast
Showing results 61 to 70 of 83
Thread: DaemonScript Clone Anyone Interested
  1. #61
    the last version i put up on 2shared was v4.2 from then on you must click update to get the latest version.
    the reason being i wanted to keep track of how many downloads scripternite has after i added the update feature.
    so again here is the link for v4.2
    2shared - download ScripterNitev4.2.7z
    im near finished v4.8 which will support relative paths, and no more interop.shell32.dll its now fully embedded and thats where its stays thanks to vs2010. so scripternite should be fully portable, even on a burnt cd/dvd. also added runas administrator in runapp, so advanced users should be able do all sorts of administrative tasks from one script.
    ie. write to folders/registrykeys where the current user doesnt have permissions.
    ill give a list of changes when im done.
    tony
    p.s wheres some feedback currently 65 downloads and 1 person(acid) gives feedback. i have no idea wheather all scripternite features even works on vista.
    sorry but until i put a download counter u will have 2 download v4.2 from the above link
  2. #62
    20.11.2010
    19
    Can't speak for the others Tony but I'm always willing to give feedback. The features you have planned in 4.8 sound awesome!
    I'm on XP with a full admin account so the run as admin won't help as much, that is till I upgrade to Windows 7. But I like how your making the app fully portable, very cool. Can't wait for 4.8!
  3. #63
    just for the info the update server is currently down so if you download v4.2 you will have to use it for a day or two until the server is back up. ( thank alex wrecks the server then leaves for the day )
    v4.8 will be released with in the next few days
    get v4.2 here
    tony
  4. #64
    20.11.2010
    19
    Well get the server working so we can download 4.8 can't wait.
  5. #65
    sorry bout the vaporware(v4.8). i had a hard drive crash.
    i should definetly release it in the next couple of days.
    sorry i've got a lot on
    tony
  6. #66
    20.11.2010
    19
    Its okay Tony. I was just bugging you before. Your making some quality software, for FREE, so I can wait a few more days or weeks.
  7. #67
    should be later tonight just got to remove a minor bug from the update form.
    hey acid if i dont fix the bug later today ill send it to you anyway and u can test it.
    tony
  8. #68
    v4.8 is uploaded to server.
    so download v4.2 at the below link, then use the updater to get v4.8
    changes
    ScripterNite v4.8
    Should fully support relative paths.
    Removed interop.shell32.dll from the ScripterNite directory, it's now completely embedded.
    Should be fully portable on burnt CD/DVD/BD, USB Drive etc...
    Added run using administrative privilages in RunApp.
    Added an update form with a download progess bar ( with bugs but should work ok )
    heaps more code changes, can't remember them all.
    Options Form
    Added a 1 second momentary message on the options forms when saving.
    Shortcut Form
    Removed the messagebox after successfully creating a shortcut and replaced with a 1 second momentary message.
    Only adds icon paths to the IconPath DropDownBox that have an embedded icon.
    Now Adds icon paths to the IconPath DropDownBox after manually selecting an icon from the icon picker dialog.
    AND DON'T FORGET SOME FEED BACK!
  9. #69
    20.11.2010
    19
    Hey Tony. Thanks for your efforts. I got your email too. I'll update to 4.8 tomorrow night late and let you know how it goes.
  10. #70
    20.11.2010
    19
    Downloaded 4.8 through internal update. Worked fine removed the interop.shell32.dll from the ScripterNite directory. Ran and tested my 4.7 shortcuts works fine. Recreated them in 4.8 just to test it out and works great. Another quality release.
    Oh and I updated my Daemon Tools Lite to the latest version too 4.40.2. Still works great!
