Page 2 of 2 FirstFirst 12
Showing results 11 to 15 of 15
Thread: YASU 1.6.9.9040 not compatible with DT 4.35
    07.10.2006
    157
    I said 'copy', not renaming it.
    Upgrade your programs:
    Exactly, that's why I said 'also', meaning I tried both things and neither worked. I first tried renaming the file, and when that didn't work, I went back and copied DTLite.exe and named it DTPro.exe, which also did nothing to effect the error that it's still giving me.
    All I'm asking for is a small walkthrough of creating a Hard Link. I pulled up the Command Prompt, but I couldn't seem to figure out the exactly right string to type in to create said Link.
    07.10.2006
    157
    If copying does not work for you, Hardlinking wont work either!
    You need to have both DTLite.exe, DTPro.exe and YASU.exe in the DeamonTools directory and you need to start YASU from there (so that it's working directory is the DT directory).
    It will work if you follow these steps.
    Default Rename
    DTLite 4.35.5.0068
    Y.A.S.U 1.6.9040
    Was getting the cannot locate daemon.exe or dtpro.exe.
    I had to rename DTLite.exe to Daemon.exe for YASU to recognize. Dont forget to edit your Shortcuts and startmenu links after doing so.
    29.03.2010
    1
    Unglücklich
    It's doesn't work for me either.
    I did this:
    1. Copy DTlite.exe
    2. Rename the copy to "daemon.exe"
    3. Run Yasu.exe in the same directory as Daemon Tools
    I even tried the same but renaming to "DTpro.exe". And I finally tried the hardlink.
    But Yasu is still saying that it can't find the "unable to locate the file daemon.exe or dtpro.exe blah blah blah".
    I have daemon tools lite 4.355.0068 and YASU 1.6.9040
    What can I do?
    Thanks a lot
