Page 3 of 3 FirstFirst 123
Showing results 21 to 29 of 29
Thread: Security softwares DT has problems with
  1. #21
    Comodo Internet Security 2011's Defense+ is interfering with DT. Therefore you have to deactivate the service completely and reboot.
    Is this just for the purpose of installing? I disabled it to install, but if I re-enable it, will I get headaches when I try to use DT Lite?
    Thanks so much!
    Oh yeah, any known issues with Avast 5.0.677 (current)?
    Thanks again!
  2. #22
    You just would get a nag.
    28.10.2010
    2
    Comodo Firewall got problem.
  4. #24
    Comodo Premium Internet Security (AV+Firewall) [CIS free] caused BIG headaches - see my replies on another thread. I think it is the AV rather than the Firewall that is causing the problems. These suddenly appeared after after recent update by Comodo. Even uninstalling Comodo did not fix the problem - I had to use System restore to go back to a point before the update.
  5. #25
    Is not a problem, i posted fix somewhere in the forum before.
    1- Install it normally
    2- Go to Comodo, Defense +, Defense + Configuration.
    3- Go to execution control tab, and click into "Exclusions/Exclude button", add DT Folder (for example, C:\Program files\Daemon Tools Pro).
    It should work perfectly now.
  6. #26
    Default daemontools.hu
    Microsoft security essential warning: this trojan
    Legfrissebb Daemon Tools Letöltése magyarul ! | DaemonTools.hu
    (DTLite4451-0243.exe)
    Hungarian page its fake???
  7. #27
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Quote Originally Posted by PowerPista View Post
    This site is not related to our company or our partners. Please use DAEMON-Tools.cc.
  8. #28
    I got DT Lite 4.49.1 a few days ago and my Windows 8.1 laptop is now stuck in a BSOD boot loop. I had IOBit Malware Fighter Pro on there, as well as Windows Defender.
  9. #29
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    If you can't access the registry in Windows please download and boot with Kaspersky Rescue Disc 10, open its Registry Editor.
    Go to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\s ptd, and double-click the DWORD value named 'Start' on the right.
    Now change the 'Value data' to 4 to disable SPTD; press OK and reboot.
