Showing results 1 to 2 of 2
Thread: question about playing a ISO file
    Default question about playing a ISO file
    I have a question about playing a Iso file,Is there a way to play the files before copying them to a DVD to check the quality? And how do I copy several file at one time
    You can mount the iso and then install the game. If the installation succeeds, the files are ok.
    If there is a copy protection present, you won't be able to start the game because iso does not contain all neccesary information. Scan the mounted iso and the installation folder with ProtectionID to find out which protection is used.
    Recreate you image(s) in mdf/mdx format with appropriate profile.
    Also you might want to take a look here:
    DAEMON Tools Professional Help: Program overview
    DAEMON Tools Lite Help: Introduction
