Page 2 of 2 FirstFirst 12
Showing results 11 to 13 of 13
Thread: Backup with Protect DiSC v9
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    Even though it's activated by default in the standard Protect CD/Protect DISC profile, DPM is not required for ProtectDISC on DVD - only on CD.
    And don't attach the SCSI device - only the IDE device. Remove all other virtual devices but the IDE one.
    If you don't have access to the customer forums here's the grabber i was refering to, only with that you'll get a perfect image:
    Attached Files Attached Files
    Thank youuuuuuuuu Terramex
    That works perfectly with the grabber. And I don't need to ignore read errors because with that there was none. The copy is perfect.
    Also, using the grabber to create the image, I haven't any message saying that the emulator is detected even if the IDE virtual drive is attached to the physical drive.
    Thank you again, I am very happy to can make a backup of my disc.
    Do you think it would be possible to burn this image on a standart DVD if I want to duplicate my original disc for the future ?
    Customer
    Terramex's Avatar
    06.09.2004
    2,572
    Quote Originally Posted by andre10 View Post
    Unfortunately not.
