Showing results 1 to 9 of 9
Thread: Daemon Tools Pro 6.1, Windows 8.1 x64 in user mode, drive add automatically
    19.03.2015
    3
    Default Daemon Tools Pro 6.1, Windows 8.1 x64 in user mode, drive add automatically
    when I create one virtual drive, after reboots additional virtual drives are being added automatically without my intention, so I start with e.g. drive F: and after several reboots DT adds addl drive such as G: H: I: J: K: and so on.
    So I need to delete all drives and without any drive, no drives are beeing added automatically.
    I work with Windows 8.1 not in Admin mode but in standard user mode.
    User
    09.10.2005
    53
    same Bug here.
    I work with Windows 8.1 pro 64bit Update 2
    07.10.2010
    1
    Please give more clue to us.
    Is your drive empty or mounted?
    What type of device is added automatically (DT, SCSI, IDE)?
    Is SPTD driver installed?
    Do you have any physical device in your system?
    How quickly does drive appear after starting OS?
    Has old version of DTPro was installed on your OS? (was it update or first install on clear system)
    Do you have another devices emulation software on your system?
    19.03.2015
    3
    - Drive is usually empty
    - DT Drive
    - SPTD is not installed
    - Yes, a BluRay burner as drive E:, an Samsung SSD and a Raid Controller with 4 HGST drives attached. System is P9X79 Deluxe, 32GB RAM.
    Antivirus is BitDefender
    - After log in, the plug in sound of the DT drive appears in about 8 seconds
    - System was a clean setup, no former release of DTPro installed
    - No device emulation software but DVDFab and AnyDVD which presumably install filter drivers. However, both are not running in background usually.
    I need to add something: the drives seem to be added intermittently, so there need to be made several reboots before additional drives appear.
  5. #5
    19.03.2015
    3
    I could now verify the failure. I appears when you have a single DT drive in one user account and then, when you switch over to the other account (e.g. Administrator), another drive is being added.
    As long as I stay in one user account, no drive is being added.
  6. #6
    bwes's Avatar
    21.03.2005
    4
    where do u see that u have windows 8.1 pro 64 bit UPDATE 2?????
  7. #7
    bwes's Avatar
    21.03.2005
    4
    same problem here
  8. #8
    I have the same Problem on Windows 10 Pro and I had the problem even under Windows 8.1 for about half a year.
    Again and again I when reboot my pc, I have a new virtual drive in the list. I always has to remove them manually.
    For one period of time I get even new physical drives I do not have.
    Thanks for your support.
Name:	2015-09-18_DAEMON Tools Pro.jpg
  9. #9
    I've the same issue here on Win 8.1 x64 and Win10 x64
