Page 3 of 7 FirstFirst 12345 ... LastLast
Showing results 21 to 30 of 65
Thread: SCSI Blacklists - or why some perfect images won't run with Daemon Tools v4
  1. #21
    Kitna's Avatar
    24.02.2003
    479
    My boot time hasn't changed that I can see.
  2. #22
    Well.. I'm using a nForce4 (GA-K8NXP-SLI) and I cant get any starforce games to work..
    I can unplug my drives.. goes through the protection section and BAM reboot..
    I use starnightmare.. and I get the "pleas put cd into another drive" crap
    I disable the nVidia parallel controller and BAM reboot..
    No am i right in thinking this is due to my mounting from 2 SATA hdrive in raid 0??
  3. #23
    Methadon's Avatar
    10.10.2005
    516
    Quote Originally Posted by QuazzieM
    Do you have the nForce IDE driver installed?
  4. #24
    is that the one that asks "do u want the sw drivers" or something like that??
  5. #25
    21.05.2005
    5
    Quote Originally Posted by NetSoerfer[U
    A special note for nForce 3/4 users[/U]
    The IDE controller that is used on nForce 3/4-based motherboards cannot be directly addressed by today's copy protections; as a result, SCSI blacklists don't work on those systems. If you are fortunate enough to have an nForce 3/4-based system, you should be able to run all the latest SafeDisc-, SecuROM- and StarForce-protected games with your IDE CD/DVD drives plugged in and working.
    with my nforce4 motherboard, it works for Safedisc, but not for SecuROM
    With Starforce, it works only on very old versions : 3.3.xx, with new versions I must disable IDE controler in device manager
    I use nvidia IDE driver
  6. #26
    Do u have a link to the latest IDE drivers..
    I might as well five it a go
    Thanks
  7. #27
    Methadon's Avatar
    10.10.2005
    516
    Thanks
    You can find them at nvidias homepage.
    http://www.nvidia.com/
  8. #28
    is there somewhere u can just download the IDE drivers seperate??
  9. #29
    Thanks Methadon for your help...
    But unfortantly after installing the latest drivers.. uninstalling the games.. removing sf and then reinstalling..
    I still ge the "Please insert the POP3 drisk into another drive"
    and when I try to disable the parralell controller or disable ata in SFN my system reboots about 25% into the protection checking
  10. #30
    Default ...
    The problem with rebooting for people with nvidia RAID devices should be fixed in the next version of DAEMON Tools.
