Showing results 21 to 30 of 44
Thread: Guide to using extra programs/addons/tools/registry hacks with the latest games
  1. #21
    09.03.2005
    166
    When burn the image on a dvd with special mediacode you are only repeat physical structure of the original dvd-rw (master disc). When publisher creat protected dvd for the game, he will write game on the dvd-rw. If you found mediacode of this dvd-rw, you can creat "ideal" physical copy of master disc without RPMS emulation. No need for this any emulators.
    About Blindwrite 6.0 - its fully bullshit. This program cannot create copy of disk this starforce.
    No really new in starforce in this moment (in emulation). Its only one new thing: they check for the emulators BEFORE physical check of disk. And in early version of starforce no any message about "emulators detected". Now starforce 4.0 display this message to prevent any reference to starforce support such as "my disc not identified, pls help".
  2. #22
    30.06.2006
    15
    Quote Originally Posted by Cuddles
    Maybe a better option is to use Microsoft Virtual PC which is free of charge.
    I can't run FlatOut2 using MS VirtualPC + iSCSI.
    But you can use another free tool: VMware server. (145Mb)
  3. #23
    Default ...
    Quote Originally Posted by xKVtor
    Could you ping the VirtualPC OS? You probably had a general networking issue.
  4. #24
    I tried it with the Virtual PC and i could access the virtual PC in the Network. I installed Alcohol on the vPC but i couldn't share the vdrive which had the image mounted (i also tried to share a dt drive with Alcohol, which worked with the 2 pc's).
  5. #25
    30.06.2006
    15
    Quote Originally Posted by Underheaven
    Yes.
    I setup network between Host OS & VirtualPC OS using MS LoopBack Adapter (on Host OS, as described in Virtual PC HELP). Then I connect shared disk via iSCSI and run FlatOut2 in Host OS. But SF begin endless disk check and freeze at last...
    There is no differences where to place MDF file: on virtual HDD or on Phisical HDD (ReadOnly,size<128Gb,FAT32). The result is the same. Nothing.
    Details in Russian
    Now I prefer to use free VMware server -- easy and powerful.
  6. #26
    30.06.2006
    15
    Cool About iSCSI + MS VirtualPC
    It is possible to using Virtual PC (instead VMware) with iSCSI method !!!
    One important thing must be changed in virual machine bios setup just before OS installing:
    1) run virtual machine and enter bios setup (hit DEL);
    2) go to POWER submenu;
    3) (!!!) change "ACPI Aware OS" to [No].
    4) save changes, exit bios setup, install OS (Win XP)
    Some notes:
    • To setup "Host OS <-> Guest OS" network: install "MS LoopBack Lan Adapter" in Host OS;
    • To attach phisical drive to virtual machine: use HDD with size <120Gb with FAT32 partiotions. Don't use NTFS partitions becouse attached phisical drive used in ReadOnly mode (WinXP don't like this mode for HDDs :wink
    You can download Microsoft Virtual PC 2004 Service Pack 1 here.
    Direct link (18Mb) to version used by me.
    Tested on FlatOut2 (DVD,Buka).
    Details in Russian
  7. #27
    26.07.2006
    1
    i tested metod with VMware and game have run but only one time, when i exit from game and start it again on same settings it was not starting like few minutes ago
  8. #28
    Here's a link to a method of getting ASR.exe to work with Titan Quest patch 1.11
    http://www.daemon-tools.cc/dtcc/show...3&postcount=11
    p.s. Just noticed that the "#2 Hiding Tools" section appears twice in the tutorial above... will have to get that fixed.
    Edit: That link is in the customer section of the forum, I'll update this post with a quote instead of a link later.
  9. #29
    Default ...
    Quote Originally Posted by cymes
    fyi: This thread is not for support questions, create a new topic.
  10. #30
    To get Titan Quest 1.11 to work, you need to do this
    (LooDos found out how to get it to work and posted it in the german customer forum):
    -copy asr.exe to your desktop or another dircetory but not into the game directory
    -rename asr.exe to explorer.exe/svchost.exe/lsass.exe/services.exe/...
    -start TQ/the game with ASR (the renamed one)
