ProtectionId Info thread - Current 6.3.5
This is a sticky topic.
  • #61
    got the files, the patch is to allow you to run any themes (without the patch you can only use signed ones).. correct?, if so, does the problem happen if you use another theme (and this patched uxtheme.dll file) ?.. if not, then the problem is in the theme itself.. if so then the patch in the dll isn't a good one
    • #62
      It seems not work for other theme either.
      • #63
        and if you use one of the microsoft themes?
        • #64
          Even with the default Windows XP theme.I found the problem exists.
          • #65
            hi, might have a new beta for you to check to see if the problem disappears (i think it might), i don't appears to be able to send you a private message on the board here, so it could be a bit tricky sending you a link for the next beta, but we intend to release another version in about 1-2 days
            • #66
              I think he needs 20 posts to be able to use the PM system. He's got 19 right now, so one more and he's good to go
              • #67
                OTL,
                That is really a problem.
                So after this post,I can use PM.
                Hope for new version.
                • #68
                  The new beta works.
                  Snapshots have been sent to you by PM.
                  Thanks for your work.
                  • #69
                    no problems, happy to help that bit of the code needed rewritten anyway, you just 'pushed' me to do it
                    • #70
                      Hehe,Both of us are winner.
                      • #71
                        new version 6.1.6 released - grab it from the main site or use the update feature...
                        some bugs fixed, more additions, more tweaks (check the changelog for more information)
                        • #72
                          Download not working.
                          • #73
                            alerted cdkiller to fix that, thanks blazi, the update should do the job though...
                            for those having problems the direct link is
                            http://pid.gamecopyworld.com/Protect...v6.1.6_2k9.rar
                            edit: cdkiller reports link is now fixed.. thanks for the speedy response blazi
                            • #74
                              Working now, thanks. Also you had one ".rar" too much in your link
                              EDIT: Once i fixed your link and you added that additional .rar again, fixed again
                              • #75
                                version 6.2.2 released today, grab update from the site, or using the update portion in pid itself... enjoy
