Showing results 1 to 4 of 4
Thread: vBulettin bug leads into lost first Post, directly after registration
    Default vBulettin bug leads into lost first Post, directly after registration
    This bug is really annoying! Itz took me some time to get my Post ready. Then I pressed the Post button and the vBulletin says sth. like "Thank you for your Post", and took me to the Place where I tried to Post it: And: nothing there! All my work on that post gone into the nirwana. No way to get it back.
    ciao
    floogy
    Hi there,
    I found out, that this forum is moderated. So I suggest to make it more clear, that one have to wait a couple of minutes up to hours till the post will appear in the forum, thanks!
    regards
    floogy
    13.11.2005
    472
    Yes, it's moderated until you have 20 posts...
    Then your post will appear immediately.
    Default ...
    I agree that it's a good idea to change the wording of that message.
