Showing results 1 to 5 of 5
Thread: Monut on double click
    11.07.2003
    2
    Default Monut on double click
    I have added the following entries in to the regisrty and get a command line error when I double click the iso. I does put daemon in the tray but not with the file mounted.
    Any ideas what I might be missing?
    HKEY_CLASSES_ROOT\.ISO
    daemontools
    HKEY_CLASSES_ROOT\daemontools
    Daemon Tools Image
    HKEY_CLASSES_ROOT\daemontools\shell
    open
    HKEY_CLASSES_ROOT\daemontools\shell\open
    HKEY_CLASSES_ROOT\daemontools\shell\open\command
    C:\Program Files\D-Tools\daemon.exe -mount 0, "%L"
    You have a wrong space between 0, and "%L". And %L should be %1.
    11.07.2003
    2
    With space or without, as a L or 1 still same result. error in command line.
    Try: "C:\Program Files\D-Tools\daemon.exe" -mount 0,"%1"
  5. #5
    This is how you have to do it.
    Code:
    # CDRWIN CUE File
    [HKEY_CLASSES_ROOT\.cue]
    @ ="CDRWIN.CUE.File"
    "EditFlags"=dword:00000000
    "BrowserFlags"=dword:00000008
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File]
    @ ="CDRWIN CUE File"
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\DefaultIcon]
    @ ="C:\\Program Files\\Ahead\\Nero\\nero.exe,50"
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\shell]
    @ ="Open"
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\shell\Open]
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\shell\Open\command]
    @ ="\"C:\\Program Files\\Ahead\\Nero\\nero.exe\" \"%1\""
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\shell\Mount]
    [HKEY_CLASSES_ROOT\CDRWIN.CUE.File\shell\Mount\command]
    @ ="\"C:\\Program Files\\D-Tools\\daemon.exe\" -mount 0,\"%1\""
    This is just an example, you will have to change the code a bit to the locations of your programs.
