Showing results 21 to 30 of 38
Thread: "Internal Setup Error. Contact Support" when i Install
  1. #21
    21.09.2006
    2
    Default I figured it out
    UNINSTALL ALL VERSIONS OF DAEMON...INSTALL THIS ONE....
    http://download.oldversion.com/daemon344.exe
    Got passed both Kernal debugger and the dam* setup error!!!
  2. #22
    Why use such obsolete version?
    Use v3.47 (available in our download section) if you don't want to use v4.0x.
  3. #23
    06.01.2007
    4
    Unglücklich
    Try 4.08 on 4 PCs, with 4.06 up and running. Same error on Windows 2003 Server R2, Vista 64, Vista 32 physical and Vista 32 virtual.
    In this last one:
    - uninstall 4.06: OK
    - install 4.08: error
    - install 4.06: OK
    Where is the solution: waiting for 4.09 ?
    I want to upgrade because I find 4.06 very very long to load an image or access the virtual drive on Vista (32 or 64). Either via GUI or script.
    Another thing: X64 version installs in Program Files (x86) folder on Vista 64 ? Not truely 64 ?
  4. #24
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    The program is 32-bit, only the drivers are 64-bit.
  5. #25
    06.12.2005
    191
    Sorry ClipOn, but i can install 4.08 in Vista (32) without problems, a full instalation, i donґt try a update from 4.06. You can try install a update sptd version manually and then update DT to 4.08 or uninstall any prior version of DT(and sptd) and try a full install...
  6. #26
    06.01.2007
    4
    New tests this last hour with 4.08-1.39:
    - uninstall 4.06
    - uninstall SPTD
    - reboot
    - start 4.08 installation
    - SPTD 1.39 installs OK and asks for reboot
    - after reboot, 4.08 install still gives the error
    - try desactivate SPTD via RegEdit, and reboot
    - error at reboot
    HELP !
    Fortunately, I can always use 4.06, it installs without any problem !
  7. #27
    Quote Originally Posted by 357mag View Post
    I also had this error.
    It was solved by right clicking on the exe file and choose option "run as". I run it as administrator on local PC and then it installed fine.
    I am normally login on a company domain, and probably some security policy somewhere was the problem.
    hey, excuse me for my realy bad english, but i'm from sweden so..:P
    anyway, i'm having this problem now. and i dont get it..
    i'm the administrator on this computer so why do i have this problem? do i still have to change something, or do i have some other problem?
    /sara.
  8. #28
    28.04.2007
    1
    Quote Originally Posted by kruxetsara View Post
    /sara.
    Testade du som de sa? Att högerklicka pе filen, vдlja "kцr som" och sen välja "administratör", skriva in lösenord och sen testa om du fеr samma jдvla meddelande igen.. det fеr iaf jag..
    Lycka till
  9. #29
    Quote Originally Posted by Eroing View Post
    Lycka till
    English only please.
  10. #30
    I have the same problem as you guys, but unfortunately nothing helps. I am the one and only Admin on the computer, and I'm not using a company-system. The run-as thing didn't work and I had no such trouble installing Alcohol (the newest one), but it was just a trial. Are we ever going to get a full solution to the problem ?
