Can you see if you have short file names created for your folder using "dir /x" ?Originally Posted by theo. t.
On my Win2k SP4 box with all updates installed, awxDTools setup fails with error message "Failed to register this extension".
When I try to manually regsvr32 awxDTools.dll, I get error message "DllRegisterServer in <Path> failed. Return code was: 0x80040201".
Short filename creation is enabled on my machine and actually never was disabled at any time.
Any idea what's going wrong?
aah, seems like theOriginally Posted by Underheaven
command hasn't worked ... there are still only short named foldersfsutil behavior set disable8dot3 0
is there a fix yet? i tried everything in this thread still dont work. tried reinstalling daemon tool to C:\DAEMON\ dont work
Hi!!
Iget the problem to awxDtools cant acces deamon.dll (or something very close to that)
Where do i type this:
Yeah i know im a noob when it gets to thisfsutil behavior set disable8dot3 0but plz help me out here. using win xp x64
you type it into the black command line window
Start Menu, Programs, Accessories, Command Prompt
Thanks Arni!! I ran the tet from a command line rebooted and registered extension from shortcut!! (can't open 'about' extension though)
Having the same issue myself, followed g31's guide to fix this, but it still comes up with try turning off secure mode (when it is off) :/
Having NTFS generate short file names (8.3 style) is the goal! You want to see the "~1"Originally Posted by theo. t.
Can you provide a screenshot?
mh, the "~1" is there, but still doesn't work
