Try to get the DAEMON Tools folder to be listed as ~1. This probably involves a lot of deleting and recreating.
now it is "~1" but aniworx still could load .dll
damn
I'm running out of ideas. Did you uninstall DAEMON Tools and install it to that new folder and delete all the files from the folder DAEMON Tools was previously installed in? Did you uninstall and reinstall AwxDTools? Maybe there's an aniworx registry entry that needs to be deleted.
mh, searching the registry is a good idea
thx
I am running Windows XP 64 bit edition and I was having the same problem with awxDTools not registering. I tried formatting and reinstalling windows but I kept getting the same error. I also tried the other solutions in this thread but they did not work for me. Below is what resolved the daemon.dll issue for me.
Solution:
Download and install "Microsoft Visual C++ 2005 Redistributable" yes the 32 bit version not the 64 bit version (Google it. It should be the first hit). The name of the file is vcredist_x86.exe
Reason:
It seems that the installer lays down only the 64 bit version of C++ files but the x86 or 32 bit version is needed too.
How I figured it out:
I double checked the event viewer Start \ Settings \ Control Panel \ Administrative Tools \ Event Viewer \ System Logs and I saw 3 error messages. One of the error messages was
"Dependent Assembly Microsoft.VC80.MFC could not be found and Last Error was The referenced assembly is not installed on your system."
(Note: if you see DCOM errors in the log, this fix alone may not resolve the issue)
I researched the error and it referenced files that should have been installed by the "Microsoft Visual C++ 2005 Redistributable (x64)" but these files did not work. I then used the 32 bit version "Microsoft Visual C++ 2005 Redistributable" and it worked. I then uninstalled everything, rebooted and installed Daemon Tools then awxDTools. I received the daemon.dll error. I then installed "Microsoft Visual C++ 2005 Redistributable" and "Re-Register Extension". It registered fine. Now I can right click on images and mount them.
I hope this helps.
this is the download link
i will try it, thx
Indeed this DOES help! I have been searching for a solution for over a month- I configured a few x64 machines and they ALL had the exact same problem. Tried everything in this thread to no avail, but your solution solved it! Thank you so much! It would make sense that the developer would have these libraries installed, and as a result may have overlooked their necessity for the end users- excellent find. This is of course not meant to bash ArniWorx in any way- no one could possibly complain about fabulous free software- but we all have so many variables to deal with, it can be an impossible task to keep up with all of it.Originally Posted by alii
Again, thank you- this is truly excellent fact-finding and troubleshooting on your part.
u r a god among insects. i never thought i'd find a fix.
Just as an aside, I found a way to trick this program into working with Alcohol as well for those interested. I did as suggested and installed the Visual C++ package first (not sure if it actually was required, but better safe than sorry). I then tried installing awxDTools into the Alcohol Soft\Alcohol 120 directory, but it couldn't locate daemon.dll. So I made a copy of alcoholx.dll and renamed the copy to daemon.dll in the same directory and proceded with the install like normal. I've tested and it absolutely does work. Now I don't have to load up Alcohol or set it to start at boot everytime I want to mount/unmount an image.
Just an update, I also found out this adds context menu support to the virtual drives themselves upon reboot. I didn't discover this at first because I rarely reboot (and the installation didn't require me to). It still says "Daemon Tools" in the context menu, but at least it's working.
