awxDTools keeps saying something about a .dll
  • #31
    neat
    That's a really neat hack Jito
    • #32
      I also discovered if I hex-edit the awxDTools.dll file, I can modify the context menu to read Alcohol-Soft instead of Daemon-Tools (just looks better when I'm using Alcohol instead of DT).
      • #33
        I have the same problem (failed to register). I'm using Win2k (futils is a part of XP but not for Win2k).
        please give me a solution
        • #34
          Re: awxDTools keeps saying something about a .dll
          Please upload a screenshot like theo. t. posted. You probably have short filenames already turned on.
          Look for the mention of "NtfsDisable8dot3NameCreation" on this webpage: http://www.microsoft.com/technet/sec.../swin2k06.mspx
          • #35
            I'm still getting failed to register extensionon win2k3 x64
            I installed both Visual C++ 2005 Runtime Libraries x86 and Visual C++ 2005 Runtime Libraries x64
            then I ran fsutil behavior set disable8dot3 0
            then I installed daemon tools in c:\daemon, turned off secure mode and installed awxdtool in c:\daemon
            I got the error again , I tried twice to be sure
            on win2k3 32bit it works just fine, what's the problem ?
            • #36
              Originally Posted by alii
              I am running Windows XP 64 bit edition and I was having the same problem with awxDTools not registering. I tried formatting and reinstalling windows but I kept getting the same error. I also tried the other solutions in this thread but they did not work for me. Below is what resolved the daemon.dll issue for me.
              Solution:
              Download and install "Microsoft Visual C++ 2005 Redistributable" yes the 32 bit version not the 64 bit version (Google it. It should be the first hit). The name of the file is vcredist_x86.exe
              Reason:
              It seems that the installer lays down only the 64 bit version of C++ files but the x86 or 32 bit version is needed too.
              How I figured it out:
              I double checked the event viewer Start \ Settings \ Control Panel \ Administrative Tools \ Event Viewer \ System Logs and I saw 3 error messages. One of the error messages was
              "Dependent Assembly Microsoft.VC80.MFC could not be found and Last Error was The referenced assembly is not installed on your system."
              (Note: if you see DCOM errors in the log, this fix alone may not resolve the issue)
              I researched the error and it referenced files that should have been installed by the "Microsoft Visual C++ 2005 Redistributable (x64)" but these files did not work. I then used the 32 bit version "Microsoft Visual C++ 2005 Redistributable" and it worked. I then uninstalled everything, rebooted and installed Daemon Tools then awxDTools. I received the daemon.dll error. I then installed "Microsoft Visual C++ 2005 Redistributable" and "Re-Register Extension". It registered fine. Now I can right click on images and mount them.
              I hope this helps.
              This worked beautifully. Thank you!
              • #37
                ok, took me quite long to switch from 3.47 to 4.0.3 because of problems installing sptd and awxDTools (w2ksp4). Now I tried again and got the daemon 4.0.3 running but awxDTools still fails to register the dll. Seems only a few people still use w2k - so not much help here.
                What I did and what seems to go wrong:
                - tried to install awxDTools -> result is the error when trying to register the dll
                - copied all registry settings from a wxpsp1 and put them in my w2k registry with the failed install -> awxDTools appears and seems to work ... at least a little bit
                - most of the images (iso, cue, mds - all the same behavior) do not mount with 'unable to open file in kernel mode' error message, but if you put any image to the root directory of any drive it works! (or change all subdirectories to uppercase)
                Ok, I found something about wxp and ObCaseInsensitive (interesting for all but win32 like posix) to turn case sensitivity of, what seems to be default on wxp and impossible on w2k. Also somebody mentioned Alcohol 120% accessing images with uppercase file and path (visible in history) and making problems this way.
                If you try to mount an image using command line you'll notice that the path is case sensitive. Drive letter and filename are not. Does awxDTools pay attention to this? If not, is it possible to fix it? Or is it possible to make posix case insensitive in w2k?
                Maybe this points even to the install problem in w2k although a test with uppercase names failed
                arniWORX, could you please take a look at the problem?
                edit by Admin: Please don't post your message more than once. The forums are moderated, which is why your posts don't show up immediately.
                • #38
                  Here is how i did it.
                  Uninstall awxdtools
                  uninstall daemon tools
                  make sure 8.3 filename creation is on by following steps below:
                  1. click start
                  2. click run
                  3. paste "fsutil behavior set disable8dot3 0"
                  4. click enter
                  5. reboot.
                  install latest daemontools, i have 4.06
                  right click the tray icon, select options, make sure "secure mode" is not checked
                  next go here http://ccollomb.free.fr/unlocker/
                  install unlocker
                  go to daemontools directory
                  right click deamon.dll
                  select unlocker, select unlock all
                  install awxdtools
                  reboot
                  turn back on secure mode on deamon tools
                  enjoy.
                  • #39
                    well Joules i tried that i'm running Vista 64bit with all the latest version of everything and i tried your fix and unlocker dosen't even open when i try to open the dll with unlocker what am i supposed to do
