Page 2 of 2 FirstFirst 12
Showing results 11 to 14 of 14
Thread: CD/DVD changer emulation
    Default Mount from inside MCE
    I think it would be great to mount images directly inside Windows Media Center.
    The settings can have an init dir to start from and then just show all the supported images.
    To go one level up there could be an icon showing two (traditional) dots [ .. ]
    Default DT MCE plug in
    Have you any plans to make a plug-in for Windows MCE? It would be a lot easier if you could mount the image directly in MCE without having to mount it first then play it. Plus you could use the remote!
    MyMovies 2 already has MCE support for DT
    MyMovies is annoying because you need to manually register all your movies in a database first before you can mount them via MCE. MediaPortal already supports one click mounting of ISOs using Daemon Tools, but I'd be thankful for a plug-in for MCE as well because I prefer MCE over MediaPortal.
