Page 5 of 7 FirstFirst ... 34567 LastLast
Showing results 41 to 50 of 69
Thread: Tomb Raider Legend 1.1
  1. #41
    17.11.2005
    21
    so if you have no IDE optical drives on your system but only the demon tools virtual drive will it then work?
    I ask as I have no internal DVD drive and am thinking about getting tomb raider.
  2. #42
    Quote Originally Posted by clemento
    mmm one second so you want to buy the game without having dvd-rom or i want to think you have any external driver
    ,because warez are forbiden here and respect your question you need to run the game the dt and some antiblacklist software and sometimes maxi or mini images
  3. #43
    19.11.2005
    12
    Quote Originally Posted by tombman
    ok, here is the solution.
    1.) use renamed antisecurom .exe and .dll mentioned above
    2.) use good image of trl
    3.) trl image has to be the ONLY image mounted in DT4. Number of drives not important. (i double checked and it was clear)
    Emulation can be left on...
    This works for me,only did part 3, however their is so much lag on the menu's & in game that it is now unplayable, gonna go back to 1.0, till someone can solve this 100%, any one else with this problem?
  4. #44
    Experienced User R!Co's Avatar
    13.08.2003
    212
    Btw Tomb Raider 1.1 is SecuROM 7.21
  5. #45
    17.11.2005
    21
    Quote Originally Posted by maylat
    Yes I do have an external DVD burner that i use to create the image, I don't use Warez! Just to point out that i've been a member of the Alcohol community for some time and do not condone the use of Warez by anyone. Hope that clears things up for you.
  6. #46
    Rotes Gesicht
    I Have to THANKSSSSSS!!!!!!
    I modificate the Antisecurerom with hex editor and it WORKS PERFECTLY.
    Before that, I fixed the exe, and game crashed sometimes
    (trl.exe error...), but now is perfect... all of this....
    Thxxxxxx a LOT...
  7. #47
    sYk0's Avatar
    27.12.2005
    392
    Blinzeln AntiSecuROM
    Quote Originally Posted by Piro_Loko
    Thxxxxxx a LOT...
    No need for the above... a new version of ASR will be released within the next few days...
    Great job to the author of ASR...
    Mail:
    curerom @ daemon-tools.cc
  8. #48
    i apologize sorry for my commnets to you one question with your driver you can run games witout dt , i mean buring the image to dvd with alcohol and run direct for dvd the latest securom and starforce version tanks
  9. #49
    New version of Curerom 2.0 beta has been released. I can't get it to work successfully with Tomb Raider v1.1. I get the error: "A required security module cannot be activated".
  10. #50
    sYk0's Avatar
    27.12.2005
    392
    You may be running some software in the background that has been blacklisted by SecuROM...
    AnyDVD, CloneDVD, Anti-Blaxx... ect...
    Mail:
