Page 2 of 2 FirstFirst 12
Showing results 11 to 17 of 17
Thread: Diablo 2 Lord of Destruction
    Default Similar question
    I also backed up my Diablo 2 files on 3 cds. I try to install from the cds and once the game is installed it asks for the play cd. I tried all 3 cds and none of them will play the game. What am I doing wrong here?
    So if my backup iso from PowerISO of LoD disc doesnt work, I need to make which type of file with which type of program to play with daemon?
    Use Alcohol 120% and use its native mds/mdf file format.
    Erm i have only a tiny problem. I have installed both Diablo 2 and Lord of Destruction cd's no problem.
    The problem exists when i click the icon to play the game, it begins to start up and asks me to make sure the Expansion disk is in. I check my computer drives and it says that the expansion disk for lord of destruction is in the virtual drive.
    Any ideas on what i should do?
    How have you created that image?
    SPANISH TRANSLATOR OFFICIAL TRANSLATOR
    26.02.2006
    48
    The "Diablo II v1.12 Patch" removes the game protection, try to install it, maybe this will fix your problem.
    Quote Originally Posted by Tanatos View Post
    The Patch worked for removing the protection. That helped ALOT THANK YOU !!!
