maybe u should upload the screenie to an image hoster, coz i dunno if we can directy connect to your pc![]()
Look to the left in the second screenshot. There's some stairs. You may need to stack some stuff to get up there, but that's your next move.
No this is an A.I. Bug. You need to update the game ôr try this:
QUOTE
1. Go to your SiN directory
2. Go to SE1 folder, then CFG folder
3. Open up autoexec with notepad (open with... command by right clicking)
4. Now are you are suppose to see: ai_norebuildgraph "1"
5. Erase that line, does not matter, doing so will prevent the game from setting it by default to 1 every time you load a save game
6. Now, if your CONSOLE does not work, enter this in the autoexec cfg file:
bind "p" "toggleconsole"
7. Open up SiN Emergence, and load your game. (note don't save after you realize you can't go any further, otherwise, it might not work)
8. Just open up that game, and before getting to the part you are going to be trap between him and the magnetic shield (??), save your game.
9. Press escape to get to the menu, tap P to bring down the console and enter this command:
ai_norebuildgraph "0"
10. Load the game you just saved.
sysProfile (Click me)You weak pathetic fool, it's all to easy
I assumed the AI Disabled message was intentional and that he couldn't figure out where to go next.
You need to rotate the kran and jump on it to get to the other side where you can go upstairs to the man behind the glaswall.
Then read my message above, and you will get it !
Try ai_norebuildgraph "1"
hi,thx 4help,i know how to go up but thats not where i,m stuck
i'm here between man and gas,please tell me whats next.
now i solve the sitting problem![]()
