Showing results 1 to 3 of 3
Thread: Alcohol can't burn RMPS
    14.05.2006
    1
    Default Alcohol can't burn RMPS
    I just got a problem.When i try to burning a DVD in alcohol with RMPS on, the program only show "Cannot start RMPS process, something has failed" than keep burning it.Of course the disc have no rmps include in it..... Anyone know how to slove this problem?
    Edit by NetSoerfer: The forums are moderated which is why your posts don't show up immediately. Please don't double post.
    If you installed a Starforce game then uninstall the SF Driver using this tool:
    http://onlinesecurity-on.com/downloads/sfdrvrem.zip
    Have a look at the supported drives list and get the latest Alcohol version:
    http://support.alcohol-soft.com/en/drives.php
    you could also send a System Report to the Alcohol Support Team here: http://support.alcohol-soft.com/en/emailsupport.php
    { "Your computer is fine sir, the problem exists between the keyboard and chair" }
