Rise And Fall: CaW - Starforce 3.7
    I don't have DVD's with one of the mediacodes but i read in forums that this trick does not always work.Sometimes it works and sometimes not.If you have the CD version you can try to use the special patch and burn the image to cd and this will work 100% but it will work only for the cd version.If you are interested PM me to tell you more about the patch.
      i don't know why but i can't pm you, i get this message:
      MakaveliTha, you do not have permission to access this page. This could be due to one of several reasons....
        Write me a mail.My email is neptun@data.bg
          You need to have at least 20 post to be able to use PMs
          Carpe diem
            Yes there is the tool wich modifies the mdf/mds file for the cd's media.... The problem is nobody found it yet.
            but for now it still the same burn the 1:1 copy and hope for the best.... and get DVDinfopro.
            DAXON...D42.9
            BenQ
            Eron
            Fujifilm
            Medion
            PHILIPS.041.9
            BenQ
            HP
            LG
            Maxell
            Memorex
            Philips
            Sony
            TDK
            RICOHJPNW11.9 ( On DVDinfopro at least for me shows as RICOHJPNnW1 or RICOHJPN1W1 )
            BestMedia Platinum
            Fujifilm
            Imation
            Maxell
            Memorex
            Octron
            Philips
            Ricoh
            Ridata
            Sony
            TDK
            Traxdata
            Quick Format the DVD-RW with dvdinfopro.
            and burn the image with alcohol 120% on 4x without rmps.
            Worked for me anyways.
              Please someone who knows how to solve this problem, post!
                buy DVD+RW from these brands and media code:
                burn without RMPS and newest alchol. play.
                maybe you need a IDE to USB cable, not all IDE work this way.
                  You must burn on DVD +RW with mediacode 041.9 without option RMPS of Alcohol. In this way you don't need to unplug your IDE drives. The games well works. For searching media code use DVD info PRO 4.36. Bye bye
                    well i made an image with alchohol 120% mounden with daemon 4.03.The prob is that it asks for cdkey and when i put the one from the original cd it does not work
                      You can not mount the image and it to work.You need to burn on a specific dvd media.
                        too bad I only have 5 dvds here and none of these are from those brands..
                          wait til a DT update will be released and u will hopefully be able to play it without burning it on specific DVDs.
                          My sysProfile!
                            i burned it on a Intenso DVD+RW and it worked fine , other ways didnґt worked for me
                              silly question, is just that i'm new and i don't have acces to different brands of dvd-rw, anybody got the dvd image running without having to burn it?
                                @teobf: atm this is simply not possible. u will have to wait for a new DT version...
                                My sysProfile!
