Page 1 of 2 12 LastLast
Showing results 1 to 10 of 14
Thread: How do I install Securom loader or YASU
    17.06.2006
    1
    Default How do I install Securom loader or YASU
    how do I instal/ use securom loader 1.2?
    There is no need to install it. Just donwload it (--> download section->3rd party for v4) and extract it. Then start the asr.exe and choose the executable of the securom 7 protected game which you want to start/play.
    Default can't get it workin' with securom loader 1.2 :(
    i can't get it working with securom loader 1.2 how do i do?
    "There is no need to install it. Just donwload it (--> download section->3rd party for v4) and extract it. Then start the asr.exe and choose the executable of the securom 7 protected game which you want to start/play." i have tried that but it still says "no disc inserted" or " wrong disc inserted" shall i install it with the securom loader or do it after i have installed it? and shall i mount the game image file while i use the loader?
    sorry for my noob-ness but i'll be happy for an answer!
    thanks.
    Kinlaadare's Avatar
    24.05.2005
    697
    You don't install it. You just need to extract it somewhere on you hard drive, your desktop for example.
    Before using it, you'll have to mount the image of the game you wanna play, cancel everything that pops up, and then doubleclick on asr.
    Now you have to choose an executable. Choose the one used to start the game, in the folder where you installed the game ( This is usualy "c:\program files\name of the game". This information is available when you right click on a game's icon, under proprieties.)
    Carpe diem
  5. #5
    Elandril's Avatar
    18.09.2005
    333
    With more recent Securom versions it also helps to rename the executable file from "asr.exe" to a random name (e.g. "thisisareallyrandomname.exe").
  6. #6
    Default no hope
    unfortunatly secrom has changed the way their program works. the latest version of the loader will be of no help. have that problem with hitman blood money. theres nothing we can do i dont think, until deamon tools updates it, or a newer version of secrom loader comes out.
  7. #7
    03.02.2008
    1
    Default Problem in using secrom 1.2
    Sorry to bother you with these nooby questions but i have a doubt.
    I open the imagem of the game i want to play with daemon tools, then i execute ars.exe, i choose the game icon in his directory and it appears this message : "A security module required can't be activated. This program can't be executed(12005)".
    What can i do ?
    Tnx for your attention
  8. #8
    SecuRom loader is outdated, use YASU instead.
    10.02.2008
    1
    If I want to start the game I get following mesage:
    "The indicated equipment, and/or the path or the file cannot be accessed. You order possibly not over sufficiently authorization, in order to be able to access the element."
    Can you help me please?
    Sorry if its bad english, I'm from Germany and don't have enough nerves to translate it perfectly.
  10. #10
    Default Yasu 1.4
    I ran a YASU exe file by the viruscan web site, and three of the programs showed some sort of trojan within the EXE file. Anybody else with this problem?
