Support VSO Blindwrite 6 (Updated Plugin Testing Here)
  • #31
    i have fix it just now.. btw it was madden 06 with safedisc 2
    • #32
      Blindwrite 6 AUDIO_CD.B6T
      Hello Andareed,
      Did you receive my AUDIO_CD.B6T file ?
      Were you able to reproduce my issue, where it always seems to play Track 01 regarless of what track I select ?
      Thank you !
      • #33
        No, I didn't. Did you email it to andareed@daemon-tools.cc?
        • #34
          So far, so good. Everything is working fine for me. Great job, Andareed!
          Also, new version of BlindWrite (6.0.0.16) is available:
          Code:
          http://download.vso-software.fr/BlindWrite6_setup.exe
          Hominis est errare, insipientis in errore perseverare
          • #35
            Hi there,
            Andareed found the issue why my Blindwrite Images (AUDIO CD) would always play the Track 01 even when choosing any other tracks.
            So make sure to update your BW5mount.dll [July 14th, 2006]
            Also, be aware, there seem to be a bug in Blindwrite v6.0.0.16 that will not finalize properly on Plextor drives !
            Thank you Andareed !
            • #36
              Uhmm the http://www.csclub.uwaterloo.ca/~dtbartle/bw5mount.zip link seems to be broken, do you guys got a mirror or something cuz I need to mount B6T image on DT.
              • #37
                Today it has worked.
                But here is a mirror (July 14th, 2006):
                Code:
                http://rapidshare.de/files/26020311/bw5mount.zip
                • #38
                  Code:
                  http://download.copybase.ch/daemontools/plugins/bw5mount_1-1-0-0.zip
                  MfG, Benni
                  Mail: benni@copybase.org
                  • #39
                    this new version should improved the Plextor support
                    • #40
                      Beta ist jetzt offiziell auch ueber die VSO Seite zu bekommen.
                      6.0.0.17
                      - 0000244: [bug] improved support of plextor premium
                      - 0000246: [Bug] Media not closed after burning
                      - 0000243: [Suggestion] Blindwrite v6.0.0.16: Save window position and log window location on close.
                      - 0000242: [Suggestion] Blindwrite v6.0.0.16: Process Bar Location
                      - new translations
                      - new EZPlay 8.0.0.1
                      - install new BWA Builder
