Page 4 of 4 FirstFirst ... 234
Showing results 31 to 40 of 40
Thread: Support VSO Blindwrite 6 (Updated Plugin Testing Here)
  1. #31
    i have fix it just now.. btw it was madden 06 with safedisc 2
  2. #32
    Böse Blindwrite 6 AUDIO_CD.B6T
    Hello Andareed,
    Did you receive my AUDIO_CD.B6T file ?
    Were you able to reproduce my issue, where it always seems to play Track 01 regarless of what track I select ?
    Thank you !
  3. #33
    No, I didn't. Did you email it to andareed@daemon-tools.cc?
  4. #34
    So far, so good. Everything is working fine for me. Great job, Andareed!
    Also, new version of BlindWrite (6.0.0.16) is available:
    Code:
    http://download.vso-software.fr/BlindWrite6_setup.exe
    Hominis est errare, insipientis in errore perseverare
  5. #35
    Reden
    Hi there,
    Andareed found the issue why my Blindwrite Images (AUDIO CD) would always play the Track 01 even when choosing any other tracks.
    So make sure to update your BW5mount.dll [July 14th, 2006]
    Also, be aware, there seem to be a bug in Blindwrite v6.0.0.16 that will not finalize properly on Plextor drives !
    Thank you Andareed !
  6. #36
    Uhmm the http://www.csclub.uwaterloo.ca/~dtbartle/bw5mount.zip link seems to be broken, do you guys got a mirror or something cuz I need to mount B6T image on DT.
  7. #37
    Quote Originally Posted by bdragon776
    Today it has worked.
    But here is a mirror (July 14th, 2006):
    Code:
    http://rapidshare.de/files/26020311/bw5mount.zip
  8. #38
    Moderator
    Benni's Avatar
    04.03.2005
    287
    Code:
    http://download.copybase.ch/daemontools/plugins/bw5mount_1-1-0-0.zip
    MfG, Benni
    Mail: benni@copybase.org
  9. #39
    http://download2.vso-software.fr/Bli...etup_60017.exe
    this new version should improved the Plextor support
  10. #40
    Beta ist jetzt offiziell auch ueber die VSO Seite zu bekommen.
    6.0.0.17
    - 0000244: [bug] improved support of plextor premium
    - 0000246: [Bug] Media not closed after burning
    - 0000243: [Suggestion] Blindwrite v6.0.0.16: Save window position and log window location on close.
    - 0000242: [Suggestion] Blindwrite v6.0.0.16: Process Bar Location
    - new translations
    - new EZPlay 8.0.0.1
    - install new BWA Builder
