Page 1 of 2 12 LastLast
Showing results 1 to 10 of 16
Thread: Which one is better
    12.01.2006
    19
    Cool which one is better
    Do you think alcohol 120% 1.9.5.4327 is better for copying the latest copy protected cd's or blindWrite 6.0.0.17. Give me some suggestions so I can choose one, they're both capable of emulating most of the copywright protections and are the two best out there, but I need the best of the two.
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    I'm a die-hard Alcohol user personally (the software, not the drink). I've never used BW though, so I couldn't give you a comparison of the two.
    Experienced User streetwolf's Avatar
    26.11.2005
    116
    Hey Jito?
    Are you a support person for Alcohol? If not, them someone else over at the Alcohol forum has the same name and avatar as you.
    Default Re: support person for Alcohol
    Quote Originally Posted by streetwolf
    Hey Jito?
    He's the same person
  5. #5
    26.11.2005
    116
    So is this a case of checking on the competition?
    Wonder who the DT mole is over at the Alcohol forum? :wink:
  6. #6
    LocotusofBorg and Copytrooper are Admins in Alcohol forum
  7. #7
    26.11.2005
    116
    WOW!
    So will we see the day that Alcohol and DT merge into one?
    After all Alcohol can make one get the DTs.
  8. #8
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Alcohol and DTools share at least one dev, and Alcohol uses the DTools virtual drives. But no, they will not merge as they are seperate entities. And yes, I'm the same Jito463.
    And that's no avatar, that's my self-portrait. Didn't you know that I'm also Max Payne?
  9. #9
    06.12.2005
    191
    i used alcoholґs demo without problems or errors, but is bw more technologically updated?
  10. #10
    Default ...
    Quote Originally Posted by arisma
    It depends on which forum you use to ask that question.
