Showing results 1 to 3 of 3
Thread: Mounting ISO within ISO
    Default Mounting ISO within ISO
    I have a ISO image (ISO_1.iso) which contain just one file - another ISO image (ISO_2.iso)!
    When I mount ISO_1.iso - I see the CONTENTS of ISO_2.iso - not ISO_2.iso as a FILE!
    Code:
    ISO_1.iso        <---- Image mounted
     --> ISO_2.iso   <---- Expected contents
      ---> my_files  <---- Actual contents
    Is this a bug? Mounting ISO_1.iso in ISObuster is correct.
    Mount the iso1 which contains the iso2 into a virtual drive of DT. Make sure you have created 2 virtual drives. Then mount the iso2 into the 2nd virtual drive. Now you can access the file from the iso2 through the 2nd virtual drive.
    Quote Originally Posted by JackJack
    Code:
    Can you reproduce this situation with some small < 50MB files you can upload to rapidshare.de?
