Page 3 of 9 FirstFirst 12345 ... LastLast
Showing results 21 to 30 of 81
Thread: Titan Quest
  1. #21
    LooDos's Avatar
    16.11.2005
    694
    CureROM is indeed one of the best tools i've ever seen!
    great respect goes to sYk0!!!
  2. #22
    Quote Originally Posted by LooDos
    I found the problem with titan quest is not the exe or the miniimage is a cd key check that makes the game unstable
    So follow this steps and u can use the mini image with out problem
    Go to start, run, write regedit
    Then find HKEY_LOCAL_MACHINE , software, iron lore, titan quest
    In titan quest you will find CD KEY reg_sz XXXX.. (your key) copy this key
    Now go to the other folder 1.00.0000 and you will find (Default) REG_SZ
    Double click in default and paste the cd key used in the folder before
    Save it and ENJOY
    Xiphias
    Its pleasure to return a favor
  3. #23
    sYk0's Avatar
    27.12.2005
    392
    Thanks alot for all your support...
    Mail:
    curerom @ daemon-tools.cc
  4. #24
    27.07.2006
    2
    Default Tq 1.11
    So today there is Titan Quest Patch 1.11 out and asr.exe stopped working with the "A required security module can not be activated. This program can not be executed." error.
    Anything about it yet?
  5. #25
  6. #26
    Reef's Avatar
    30.03.2003
    860
    That link can only be seen by customers, FordPrefect
    Anyway, the workaround is to NOT put asr.exe in the game's directory. Just run it from somewhere else and the game will start.
  7. #27
    asr works but i get booted to windows everytime i step into any portal i create.
  8. #28
    23.03.2004
    547
    Ups, I didn't realise that it was from the customer forum...
  9. #29
    I must be doing something wrong. It won't work for me. Asl 1.2 crashes when I load the .exe
    I have the newest version of Asl and DT (4.03HE, SPTD 1.25)
    I also tried to unplug my optical IDE drive and start without asl but still I get an error that the game found active emulation software
    Any tips, what I might try?
  10. #30
    oh i meant "asr" instead of "asl"
    I now found out that the game/asr wont crash if I copy it to the game directory before starting it
    Now I get an error, that some security module could not be loaded
