Page 2 of 2 FirstFirst 12
Showing results 11 to 13 of 13
Thread: DvD-Cops emulation
    Ausrufezeichen alcohol didn't work!
    Thanks Venom386 for the help, i've tried Alcohol (latest version) with DPM precision normal, and i've tried about 6 speeds with no luck (i've tried 1x, 2x, 4x, 6x, 8x, 12x, and 48x i think). to be honest, it's getting frustrating! everytime i run alcohol the dvd seems to get more scratches.
    one more thing, there seems to be error sectors embedded in the dvd, i'm not sure if this is done by dvd-cops or by another protection software. so i've made alcohol skipp error blocks and i've made it jump 1 block at a time, but still nothing works.
    so , to summarize what i've been running: skip reading errors
    with default A.S.S jump factor set to 1
    and it still doesn't break the protection. any suggestions?
    also, does changing the virtual drive type (the vendor identification, product identication, and the revision level) affect this? is there any working type? i've tried to set it as my actual hardware ( a sony dvd but with no luck also).
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    For DVDs, you need to set DPM precision to High and use Maximum Read Speed. Also, don't use A.S.S., just skip read errors.
    Quote Originally Posted by Jito463
    Also no luke with this way... i tried it many time's its always stop on 38% and start Skipping errors then complete the image... but its still ask the CD....
    any suggestions?
