Showing results 1 to 4 of 4
Thread: 9 box cube floating around screen
    Default 9 box cube floating around screen
    I'm having this problem when watching movies. There is this box that starts in the upper right corner and then floats around the screen in a skittish fashion during the entire film. It's really annoying and i've tried several players trying to get rid of it. I thought maybe it had something to do with Daemon so i posted here. Any information would be great. Thanks.
    andre
    Administrator
    06.11.2002
    2,044
    No idea how it can be related to Daemon.
    Well i tried Windvd and I haven't seen the box since. Apparently it had something to do with the other players that I had been using. Thanks for the help.
    Andre
    11.06.2003
    18
    Operating System: Win XP pro
    Burning Software: Alcohol 120
    Anti-virus Software: Norton AV
    As far as i know this box shows you are using the elecard-video codec (used for mpeg-playback). This flying box shows that you havenot purchased this codes, its running in test mode.
    Its most commonly installed with DVD or DVB-Software, for example Progdvb installs this filter. As it is a directshow plugin, most standard-players will use this codec from now on. Of course Software like Windvd have their own playback-codec, so there these box does not occur.
    Hope i could be of some assistance.
