Showing results 1 to 8 of 8
Thread: Where can I find a list of support image formats?
    Default Where can I find a list of support image formats?
    I couldn't find a list on the forum or site.
    23.03.2004
    547
    If you mount an image with DT you can see which formats are supported.
    cue, iso, bwt, cdi, b5t, ccd, mds, nrg, pdi
    And if you have the BW6 plugin then the new b6t image files from Blindwrite 6 will also be supported.
    LooDos's Avatar
    16.11.2005
    694
    just curious to know: will the bw6 plugin be integrated in future versions of DT?
  5. #5
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    I'm sure it will, but they have to add b6t to the list of recognized image formats first and then reupload the package with the updated plugin, so it won't happen until the next official update at the soonest (as opposed to the re-release of 4.0.3 just to add SPTD 1.25).
  6. #6
    Quote Originally Posted by Jito463
    Do you mean that it'll be shown in the image choosing/mounting dialog of DT?
    This is already done by the plugin (bw5mount.dll file).
  7. #7
    Default ...
    I agree with Analcobra. When you drop in the new .dll DAEMON Tools becomes aware the new file extensions.
  8. #8
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Ohh, I see. I was not aware of that. Thanks for clarifying (I don't have DTools installed currently and Alcohol doesn't support that, so I wasn't able to check).
