Page 2 of 2 FirstFirst 12
Showing results 11 to 17 of 17
Thread: MOHAA trouble
    Well, as I said use CloneCD4, and try to create an image without fast error skip ... if you donґt want to wait for all those SafeDisc errors to be read, you can use Daemon Tools fast dump feature if you want ...
    and check the log ... first error should be sector #811, last error should be sector #10019 - there must be NO other errors between #0-810 and #10020-end!
    28.11.2002
    7
    yea thats exactly what ive been seeing, errors start and end on exactly those sectors..... bah i give up, ill try clone cd 4 again even tho same thing happend with that
    If even the originals fail with the Version you installed from the images, it's possible that the images contains serious readerrors. Try to create the image with lower read-speeds, I've been in trouble long time ago to create a image even from Safedisc 1 protected game (Rune) -> disc was scratched !
    I've tested Daemon Tools with Image of MOHAA, created Image with BlindRead -> works flawlessly.
    i too am experiencing the same problems... if i understand clearly what your saying... i have made a back up of the cd... with CloneCD4... the image when mounted by Daemon tools works great... it installs and plays from the image fine... but when i make the image onto a cd... its that cd that will not play the game... i think somehow the cd-check doesnt transfer onto the cd ?? even with clonecd4's hide cd-r and daemon's emulators activated.. the cd itself will not function with the game? i have heard of a function with daemon tools that allows copies of this to work.. its been suggested its called fastdumping... but i still cant get it to work? can someone detail step by step what needs to be done?? thanks in advance..!! :?
    Your problem is different, it has to do with the copy protection of MOHAA (SafeDisc 2.51.021) - if you want to use fast dump just enable Daemon Toolґs SafeDisc emulation with your original cd in your cd/dvd drive, start MOHAA, exit it, then create an image with e.g. CloneCD -> check the log! All SafeDisc errors should be read in about 10 secs - this is how fast dump works. Write the image to cd-r(w) and play with enabled SafeDisc emulation - will work for sure!
    Okay, what the hell does this mean?
    _________________________________________________
    Component Transfer Error
    Component: Data Files Complete
    File Group: Data Files Complete
    File: D:\main\Pak2.pk3
    Error: Data error (cyclic redundancy check).
    __________________________________________________
    I get this when installing disc 2 at the said file.
    I used CloneCD 4 with no fast-error skip (also tried with FES)
    I have a Lite-on LTR-48125W with WS08 FW.
    Even tried reading at 1x, to no avail.
    Any help would be appreciated.
    THX
    errors at 811-10019 and 184535. Could this be the problem? Maybe a scratched CD? I see no visible scratches...
    It means bad backup (read error) - try again.
    There MUST be NO errors >10019, so the error you have at 184535 is the problem.
    Disable fast error skip, use lower read speed ... if you donґt want to wait so long for the SafeDisc errors to be read, use Daemon Tools fast dump feature.
