help
  • help
    i want to view iso files. What do i do?
    What do you mean by "view"? If you just want to look at the contents of the mounted image, like you'd do with a real cd you insert in a real drive, just mount the image, open an Explorer, and click on the virtual drive.
      If you havn't daemon-tools installed then install it.
      How to mount an image in the virtual drive can be found here:
      http://www.daemon-tools.cc/dtcc/daemonhelp.php
      And how to view/access the contents of the image follow Copytroopers advice.
