Possible 2 run FEAR 1.06?
  • #31
    Correction, the free, personal-use version of Alcohol 52% can create up to 6 virtual drives.
    • #32
      Ok, your right, i thought it was about 4 but its 6
      thx for the correction.
      Here the developer description
      Originally Posted by developer description
      There are no limitations on this version, other than the ability to create only 6 virtual drives. Our retail version still supports 31 virtual drives.
      Remember you can not run Alcohol 52% if you have Alcohol 120% installed on the same drive.
      This version of Alcohol 52% is for private, non-commercial, single home computer use only.The license is provided personally to you and for that reason it does not allow you to make any duplicate (copy) to be sold, borrowed, assigned, leased or transferred.
      Emulation software allowing users to play CDs DVDs without the need for the physical disc. Notebook users and PC Game players would benifit the most from Alcohol 52% Supports 25 plus languages Can handle up to 6 virtual CD DVD-ROM drives, all at once. The reading speed of a virtual CD-ROM is 200X.
      This means you can play a CD from the virtual CD-ROM with 200X reading speed. Supports normal CD DVD and CD RAW sub-channel reading methods: RAW reading method enables to emulate all CDs.
      CD formats supported: CD-DA, CD+G, CD-ROM, CD-XA, Video CD, Photo CD, Mixed Mode, Multi-session CD DVD formats supported: DVD-ROM, DVD-Video, DVD-Audio Support for all current (ATAPI SCSI) drives: CD-R, CD-RW, DVD-RAM, DVD-R, DVD-RW, DVD+RW Full support for IEEE-1394 (Firewire) and USB protocols.
