Showing results 1 to 6 of 6
Thread: Mixed Mode CD games-can't get audio side to work
    08.09.2006
    3
    Böse Mixed Mode CD games-can't get audio side to work
    I have been constantly trying over the past days to get a game that's been made in a Mixed Mode CD(data and audio side on the same disc) to play the music, which is on the audio side. The game's Sega Rally 2, and no matter what I do to the ISO or the setup of the Damon drive, the music refuses to play. Odd thing is that I have other Mixed Mode CD games whose audio sides work no problem. It gets me aggravated . What am I supposed to do?
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Given that's an older game, try setting Daemon's virtual drives to the lowest drive letter (above your HDD that is). For example, if your optical (CD/DVD) drive is D:, change it to E: and set Daemon Tools to D: and try again. Some older games like that only play their audio tracks when run from the lowest optical drive letter.
    08.09.2006
    3
    Frage
    How am I supposed to change my optical drive letters? I have two CD drives, one reader(E), one writer(D). The Damon drive is drive F. How to change my optical and Damon drive's letter?
    By the way, I used an even older game(Daytona USA) on my Damon drive, and the music works perfectly. I'm stuck.
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    Well, I did say "some" older games require that. Try changing your writer to G: and set the virtual drive to D:. If that works, you can consider other options for rearranging the drive letters beyond that. But that will serve for testing purposes.
  5. #5
    To change your drive letters, Right-click on "My Computer"
    Then choose "Manage"
    From theres, go to "Disk Management" in the left pane.
    Then Right-Click the Drive whose letter you want changed, and choose to change drive letters and paths, as illustrated here...
  6. #6
    08.09.2006
    3
    It still doesn't work. Sega Rally 2 is the only game that I have as a Mixed Mode CD that doesn't work. Maybe it's because I edited the music(it's not the arcade version's original music, and I have a second CD image, BIN/CUE(both), with the PC port's music). Any other suggestions? Anyone had experience with Sega Rally 2 on Damon Tools in Windows XP Pro(SP 2)? I need an answer fast! I don't want to trash the BIN/CUE, but I'll have to if I can't get this really frustrating problem fixed soon, and this is one of my favorite games. I may be out of luck.
    It was released in 1999 by the way, if you don't know.
