Showing results 1 to 6 of 6
Thread: homeworld 2
    Default homeworld 2
    hello,
    homeworld 2 ( french ) doesn't lauch with the last deamon-tools release ( and older )
    i've 10 computer and 10 cd, and i've already 1 cd broken and 2 striped...
    10 cd's and 10 pc`s? did you run a cyber-cafe?
    yes, but if homeworld2 doesn't work with deamon tools, i'll not use it ...
    and I think it's a good tools
    with older games we use one cd for several pc, it's necessary for the launch, but homeworld2 requires the cd several times during the game.
    i discovered d-t recently, and if it work with homeworld2 perhaps i'll use it in my cyber-café
    26.03.2003
    11
    I am sure it will load. You need to make an image of it first with a program that can do it properly. I recommend Blindwrite from VSO software.
  5. #5
    I recommend to create a working image with Alcohol 120% (latest Version).
    Use the latest Version of Daemon Tools (3.41) to mount the image, it works
  6. #6
    i will test alcohol
    with blindwrite and clone cd it's not good ;(
